Re: Cleaning out the cooling system
Posted by SuperA-Tx on September 04, 2006 at 08:01:41 from (4.90.6.204):
In Reply to: Re: Cleaning out the cooling system posted by gene bender on September 04, 2006 at 01:38:19:
Starting the tractor and letting it run is kind of out of the question, I have it torn down to much for that now.
It ran good before I started the restoration so I dont plan on tearing into the motor or going any further than I have too. Im not a mechanic so that kind of scares me to start working on the actual motor.
Plans as they are now is to run some water thru the block and then plug the bottom hole and put vinagar in there and let it sit. Then I will run water back thru it to flush it again.
Thanks Gene and Old. This Super A was my fathers he bought in 1949 (1948 model) and so kind of special to me.
