Re: 460 Diesel Injector Seals
Posted by Smith1000 on September 04, 2006 at 19:18:09 from (205.188.116.133):
In Reply to: Re: 460 Diesel Injector Seals posted by the tractor vet on September 04, 2006 at 17:17:24:
Thanks! I took a shot at it and put the seals all the way up. Have had it running. Even drove it down the road a bit in road gear. The new head gasket is nice and tight, no seeping at all.
I now just need to set the valves hot at .027 and I might check the injection pump timing. Not much clearance for the valve cover. I may have to raise the fuel tank again to get the valve cover off. It is basically done though and seems to be running fairly well. I"ll see how it starts tomorrow. Was a little slow to start this time, but did not have to pull it at least. Thanks again.
