Re: Mr. Haney pulls a new trick
Posted by Harley on September 05, 2006 at 06:29:42 from (205.188.116.133):
In Reply to: Re: Mr. Haney pulls a new trick posted by Janicholson on September 05, 2006 at 06:08:53:
And then of course it might just be the nature of the beast, just letting you know who's boss. I even had an M die out on me with a full tank of gas and I knew it was full cause I took the cap off and looked. Then it would run good for about 3 minutes. Then die. Checked the gas again and it would run for 3 and die. Now wait a minute. If the tank is full, there's not much air up there to let the fuel flow out the bottom. Looked at the cap. One of those *&(%&&$^( non vented caps. Threw it just as far down into the timber as I could. Went to the shop, got the new tall cap, wala problem solved. Hope your fix is as easy. Harley
