Re: H brake adjustment
Posted by RustyFarmall on September 05, 2006 at 11:57:42 from (216.248.75.175):
In Reply to: H brake adjustment posted by Mike CA on September 05, 2006 at 10:32:50:
Mike, there is a "parking" brake of sorts. The inside brake pedal has a notched rack attached to it. On the deck plate, close to the inside brake, is a small rectangular shaped plate. You push down on the brake pedal so the brake is applied, and then lift up on the plate. The plate will engage into one of the notches on the rack, and will lock the brake into the engaged position.
