Re: '46 H won't run past 5 minutes
Posted by Javp20 on September 05, 2006 at 12:04:57 from (165.138.165.122):
In Reply to: '46 H won't run past 5 minutes posted by Mike CA on September 05, 2006 at 09:03:50:
I once had a small bug(fly) stuck in the hole at the bottom of my fuel tank. The tractor would run great for a few minutes, then as the fuel was burned in the carb, it would begin to sputter, couldn't pull itself, etc. I removed the glass bowl under the tank and noticed only a small trickle of fuel coming out so I removed the whole fuel shutoff and found the bug blocking the fuel flow! Just one more thing to check. Good luck.
