Recommended oil for rear axle gearbox 48 Farmall C
Posted by Dan Horras on September 05, 2006 at 13:14:31 from (216.111.160.86):
Wanted to know what would be the recommended oil for the rear axle. The add plug is on the left side of the operators floorboard.
The manual i purchased has no info on these lubricants. I assume it should be some kind of hypoid gear oil.
