Re: H brake adjustment
Posted by kfox on September 05, 2006 at 18:13:20 from (63.18.251.133):
In Reply to: Re: H brake adjustment posted by moseed on September 05, 2006 at 14:46:06:
Mike, even if the linings are not worn out, you may have grease in the brakes from a leaking seal. THis is a common problem with the older Farmalls. Cleaning the linings with solivent can work sometimes, but just getting the brakes apart To work on them can sometimes be a hairpuller. If you run into problems, just post them on here.
ken
