F400 lpg What fluid should be used in transmission
Posted by VOLfarmall on September 06, 2006 at 03:33:35 from (66.19.139.127):
What fluid should be used in the transmission? it does have the T/A the operators manual says 80-90, but I use Hi-trans in my SMTA.Is there a difference? Thank You
