Re: F12 can't get 'er to start fer nothin'
Posted by John M on September 07, 2006 at 03:33:56 from (64.53.75.223):
In Reply to: Re: F12 can't get 'er to start fer nothin' posted by holt_2ton on September 06, 2006 at 16:48:38:
As I said, to choke it push the rod in.It only takes one or two pulls to get it close or youre flooding it.Put in a set of Autolite 3077s, that cured alot of my problems. When I crank mine I pull up easy, then just before the impulse clicks I jerk it a little, sometimes I just pull it easy.Set the retard to just off the shut down position and verify it on the mag as the linkage sometimes is wore out.Give it about half throttle.
