Re: 674 INTERNATIONAL DIESEL FUEL SUPPLY PUMP ?
Posted by K.B.-826 on September 07, 2006 at 16:15:10 from (68.115.95.87):
In Reply to: 674 INTERNATIONAL DIESEL FUEL SUPPLY PUMP ? posted by Scotty1 on September 06, 2006 at 19:50:02:
That stinky blue smoke is very typical for an IH German diesel running at low speed/light load/cold. Those engines need to be worked and run fast. No matter how hard you work them, they will start stinking again after letting them idle a few minutes. That's just the way they are. Your injector opening pressures sound really low. A fresh set of injectors should give some improvement. Reusing the sleeves and pistons was probably a mistake, but I'd go after the injectors first. It sounds like your tractor has underslung exhaust? If you could convert to a vertical set-up, you could get the smoke up and away from yourself.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
