Re: McCormick 45 square baler
Posted by Ben Ford on September 08, 2006 at 09:31:34 from (64.12.116.65):
In Reply to: Re: McCormick 45 square baler posted by Karl Hamson on September 08, 2006 at 09:16:59:
I have the twine thru the needle and need to know it"s entry into the knotter. That is the area that I am lost on.
fax #
1 816 680 3969
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
