Re: Oil Pressure Results
Posted by Daniel H. on September 09, 2006 at 16:18:17 from (66.226.34.159):
In Reply to: Re: Oil Pressure Results posted by BOBCD on September 09, 2006 at 07:20:34:
More than likely your going to find the cover plate on the oil pump is warped. Mine was; I changed it and it made a big improvement in the oil pressure. The cover is cast aluminum and the spring pressure does a number on it. You probably won't see it unless you take the cover off and dress it on a piece of fine sandpaper taped to a piece of plate glass. Some can be trued up that way. A new cover was around $80 two years ago. I would change the spring and you will need a cover gasket, it acts a shim. Of course, your bearings may still be worn.
Good Luck.
