Re: 400 - 3 different leaks
Posted by Jossette on September 10, 2006 at 07:31:59 from (216.114.223.168):
In Reply to: 400 - 3 different leaks posted by SDE on September 09, 2006 at 19:42:49:
third party image
the couplers are shot. replace
If oil is leaking that much, you should be able to find the seal where it is leaking and replace
good luck with the 3pt..
