Re: what is value of Super MTA diesel?
Posted by wdrew24 on September 10, 2006 at 07:53:48 from (24.74.43.5):
In Reply to: what is value of Super MTA diesel? posted by Roger C. on September 09, 2006 at 15:21:31:
I got mine 5 months ago. I paid 5k for her. She was 80% torn down, and the front half had been cleaned and primed. I have gone completely through this tractor while putting it back together. Started her up on gas about 6 weeks ago, then she wouldn't run on diesel. Pulled top of injector pump off and removed plunger valve. Valve in bottom was stuck. Good ole PB Blaster soak in a jar for 8 hours, came back and valve spring had pulled valve loose. Installed, and she runs on the D side like it was brand new. Now that I know that mechanically she is fine....I have pulled injector pump, Manifolds, distributor, radiator, and everything else that is in the way so as to get a GREAT paint job. I believe that as nicely done as this girl will be, and the way she runs, and she has factory wide IH front....I don't think you could wrestle her away from me for under 15k and in a few more years...it might take 20k or more. I know this sounds crazy but a whole lot of dual fuel motors got replaced when the head cracked. It was the weak spot of dual fuel engines.(The cause was not allowing the engine to warm-up properly on gas before switching to diesel, or running them out of water)Many a dual fuel was replaced by a gasser. Always look closely on these era tractors that you aren't looking at a gasser that was originally a dual fuel. DREW
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
