Re: M Farmall Kills Battery
Posted by Janicholson on September 11, 2006 at 06:47:22 from (199.17.6.122):
In Reply to: M Farmall Kills Battery posted by Big un on September 10, 2006 at 13:55:00:
There is a question of how fast it drains the battery. If it gets things hot, and the battery is pushing out 100 amps or so into a short, it needs to have every heavy (battery cable) checked for shorts to ground. If these are good (and "0" ga wire) then the starter switch could be grounding internally. If the switch and wires are good, then it probably is not shorting to ground, but may have the following wrong: If the voltage regulator contacts are sticking (on the cutout relay in the regulator, the generator will continue to draw current when the tractor is shut ovv (as much as 15 amps) which will kill the battery in a few hours or so. If the amp meter is connected correctly and working, this will show as a discharge even when shut off. I suspect this is ths case because the first problem (above is usually including smoke. A new regulator will probably fix the problem. If not check the archives for John T trouble shooting guide, it is sxcellent. Good luck, JimN
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
