Re: water pump zerk
Posted by Haas on September 11, 2006 at 12:46:43 from (12.65.18.247):
In Reply to: water pump zerk posted by Deb King on September 11, 2006 at 07:41:48:
One of the zerks is to grease the water pump bearings. The other greases the water pump shaft packing. Neither of these need much grease. The bearings have shaft seals and over greasing at worst may push the seals out of there seats or if the seals are not tight, the grease will come out and make a mess. If you overgrease the packing, the grease will just go into the coolant. So not much grease needed, only a couple strokes a year if you work the tractor. If you don't work it, not even that often. So the covers were there because you did not need to grease very often.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
