Re: Painting an M
Posted by Nebraska Cowman on September 12, 2006 at 10:15:13 from (65.169.97.206):
In Reply to: Painting an M posted by BOBM25 on September 12, 2006 at 10:04:56:
I probably havn't painted more than 50 tractors in my life so maybe I'm not the guy to ask. You will never get a nice job unless you get ALL the paint off the hood and fuel tank. I don't take the tank off but like the hood off. IH didn't mask much. I use gun grease on the headlight lenses and gauge glass. IH never used primer and neither do I, just squirt the red. I think sandblasting is a waste of time. Clean engine with kerosene, followed by your favorite degreaser and LOTS of water. A little wirebrushing on castings to knock the loose stuff of should be all you need.
third party image
