Re: shifting properly
Posted by Hugh MacKay on September 13, 2006 at 02:57:39 from (216.208.58.144):
In Reply to: shifting properly posted by Young and dumb on September 12, 2006 at 20:09:00:
Young: I wont call you, and dumb. Shifting those large chasis 66 series tractors on the move into that 4th speed is just not worth the effort. It can be done but you just don't have the same kind of momentum going for you as in a straight gear truck. The 1066 and 1466 have a transmission brake, hooked to clutch pedal, same idea as highway tractors, therefor you must never push clutch down far enough to apply the brake during shifting, if tractor is moving. Then you must align your engine rpm so it is in perfect sequence with gear your going to. I expect with practice you could get this right, but then you must throw in the factor of grade the tractor is on. These tractors soon stop on upgrade, especially if you happen to push clutch pedal down far enough to apply the transmission brake. 30 years ago I decided it was not worth the effort, even though I was proficient in doing this with highway trucks. Besides a 1066 is quite capable of starting away in 4th, high range and low on TA just about anywhere on hard surface with 10 ton behind it. The 1466 having more hp can only be better. Some upgrades will hamper this with the load behind, but I've never seen a spot were 1066 with 3 ton behind, couldn't start away in 4th, high range and low on TA. I will also tell you this, shifting TA in those higher gears you should adjust your throttle, to compensate for the gear change. It's all about driveline shock. These are not a Farmall M, they quite often weigh twice as much, yet have no more speed and momentum for on the go shifting. Another side note, most of these big tractors folks have been speed shifting, have the transmission brake destroyed. It's not designed to stop the tractor, only stop transmission gears from turning after tractor has been idling in neutral. The time you save shifting on the go, most likely be more than used up waiting for the transmission to stop everytime tractor has been idling in neutral with clutch out.
Home
| Forums
Today's Featured Article -
Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
