Re: Engine heater on 300 utility
Posted by SRC on September 13, 2006 at 06:27:40 from (158.136.78.65):
In Reply to: Engine heater on 300 utility posted by Jimer on September 12, 2006 at 18:00:36:
It's pretty easy. Remove the block drain plug below the carberator and replace it with a brass nipple just long enough to slip a piece of heater hose over the end of. Then, remove the temp sensor in the head and install a tee. The sensor (with a bushing) will thread into one side, a nipple with heater hose into the other side. Then you can install the tank heater between them and achive flow. It works great, I've done the same with my 300 & 340 utilities.
