Re: Super A oil pan problem
Posted by Janicholson on September 13, 2006 at 07:06:03 from (199.17.6.122):
In Reply to: Super A oil pan problem posted by Rickysa on September 13, 2006 at 06:00:22:
Hold a 2/2" nut up against the old plug and weld through the center to hold it on. When it cools, the heat will have loosened the frozen threads and the nut will be there to turn it out. Good luck, resell your new pan, or resell the one you fix. JimN
