Re: Hyd. hook up
Posted by CNKS on September 14, 2006 at 19:59:20 from (204.249.178.135):
In Reply to: Re: Hyd. hook up posted by dave loughmiller on September 14, 2006 at 19:15:43:
All of the ports, one on the right, two on the left are pressure. The rear port is intended for use with a rear mount implement, but can be used for other implements. Although it really doesn't matter, attach your cylinders to the two front ports. Unless you have the factory remote or an add on spool valve, nothing goes back to the reservoir. If you have two way cylinders (two ports) you vent the one not in use. A one way cylinder is self explanatory. The system you have is power up, gravity down. If you want 2 way hydraulics, you can mount a spool valve wherever is convenient. In that case, you run lines from the reservoir (pump) to the spool valve; from the spool valve to one port on the cylinders; from the other port on the cylinders to the spool valve--tee the cylinders together if there are not enough ports on the spool valve --; from the spool valve to a tee on the reservoir/fill cap. Spool valve is operational only with the main control rod locked back. If you have the 2-way factory remote otherwise know as a "christmas tree", the principal is the same, but I can't tell you the exact connections as I have never seen one.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
