Re: Farmall A no start
Posted by Bill in VT on September 15, 2006 at 07:04:21 from (216.107.222.234):
In Reply to: Re: Farmall A no start posted by Brian in NY on September 14, 2006 at 13:27:54:
Everthing is working fine, engine turns over.
If I get no spark then it must be a fuel delivery problem? I'll check the points and so a spark test (hold a wire against the frame?).
Thanks
