Re: Upper bolster/steering shaft
Posted by Bob M on September 15, 2006 at 08:30:54 from (151.190.254.108):
In Reply to: Re: Upper bolster/steering shaft posted by Dale Bennett on September 15, 2006 at 06:56:17:
Dale - There’s no steering gear lash “adjustment” per se. A few things you can check and maybe fix however: With the cover off the steering box, rotate the input shaft back and forth by hand and observe the movement of the gears the slack is taken up. If the worm shaft shows movement lengthwise it needs a new ball bearing on it’s front end. And if the rear end of the worm shows any radial movement, the bushing there must be replaced. If the pivot shaft worm gear shows any horizontal (front to back and/or side to side) movement, the upper pivot shaft bushing is worn. The only fix is to replace the bushing. Finally if there is slack between the worm and pivot shaft gear on account of gear wear, and the worm gear is a full 360 degree style, sometimes removing the gear, turning it 180 deg and putting it back on (so fresh, unworn teeth now engage the worm) helps. But if the gear is the “half moon” style it cannot be rotated – only solution is to replace it. ---- My experience is it’s usually a combination of all of the above causing steering play.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
