Re: Farmall Super A weights
Posted by Super A on September 15, 2006 at 09:38:09 from (208.1.217.193):
In Reply to: Farmall Super A weights posted by Dave Sherburne NY on September 14, 2006 at 17:07:33:
On my tractor, the LH side (with the pressed steel disk wheel) used carriage bolts only, the RH side (the heavy cast wheel) used regular hex head bolts. The holes on the RH are plain bored holes, not square punched like the LH side. The weights had not been removed since the tractor was new.
Al
