Re: Upper bolster/steering shaft
Posted by Roger46 on September 15, 2006 at 15:46:43 from (69.58.130.151):
In Reply to: Re: Upper bolster/steering shaft posted by Randy S.E.-MN on September 15, 2006 at 06:53:52:
I don't know why people have so much trouble putting that seal in. I do exactly as you said using washers and threaded rod. All you need to do is make sure the seal pulls up evenly as you pull it in place. I have done several of them on H's and an M and haven't had one leak. I always fill with 90 weight oil, not grease. I also usually put some non hardening gasket cement on the threads of that cap that seats the worm gear shaft to make sure it doesn't leak. Roger
