Re: Super C Not Charging-Temp Fix?
Posted by RAW in IA on September 15, 2006 at 20:43:30 from (12.216.216.73):
In Reply to: Super C Not Charging-Temp Fix? posted by terryjd on September 15, 2006 at 19:26:28:
Sounds more like cyt-out relay or regulator bad.If you charge the battery up it should run quite a while. I have a Cub with 6 volt system, and it hasn't charged for 6 yrs. I recharge battery once in a while and don't have much trouble. Battery is getting old so it doesn't hold as long now. Think I will switch it to 12 volt and use my trollin motot battery. Will start better in winter to plow snow.
