Re: Super C Not Charging-Temp Fix?
Posted by Red Dave on September 16, 2006 at 09:06:07 from (66.109.236.219):
In Reply to: Super C Not Charging-Temp Fix? posted by terryjd on September 15, 2006 at 19:26:28:
Terry, I can't get through all the dissertations below to tell if anybody said this but, if grounding the field makes the ammeter show charge, it sounds like generator is working and the voltage regulator is not.
To put it simply, assuming the wiring is OK, it sounds like you need a regulator.
