Re: More W6 Problems!!!
Posted by John T on September 16, 2006 at 09:58:54 from (66.244.90.5):
In Reply to: More W6 Problems!!! posted by chadd on September 16, 2006 at 08:17:42:
Chad, Ima thinkin along the same lines as Bob n Jim,,,,,,,,, I really wonder if the genny was incorrectly polarized n you messed up the Voltage Regulator??????? If theres a heavy discharge that can be caused by a VR that has a stuck/burned/welded cutout relay. If she was drawing a high discharge current but it stops if you remove the wire on the VR's BAT terminal, sounds like the VR's cutout relay is stuck/burned closed. If the belt is removed and the genny spins like a motor thats another sign the cutout relay is stuck closed DONT LEAVE THE VR CONNECTED IN A HIGH DISCHARGE CONDITION (remove the BAT wire) it runs the battery down n the genny gets hottttttt You need to stop n regroup n insure first shes wired correct,,,,,,then charge the battery,,,,,, then do as Bob noted n polarize the genny n insure the cutout relays NOT stuck closed. If its stuck, when you attach the BAT wire to the VR she will discharge heavy butttttttt that has to be connected before polarizing if you polarize by flashing the VR' BAT and ARM/GEN terminals together,,,,,,,you may be better off polarizing by (before connecting to VR) you flash touch the wire that goes to BAT on the VR first direct to the gennys ARM post to polarize n then attach to the VR's BAT terminal n hope she dont heavy discharge (stuck cutout relay). It may be possible to seperate n clean n light file a stuck cutout relay points n make her work again butttttttt once the shiny silver is gone n they are rough n carboned they can go bad again soon John T (NOT a W6 Man but been around the block on electrical stuff)
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
