Re: dirty ignition points
Posted by Sam#3 on September 17, 2006 at 07:07:40 from (70.185.14.245):
In Reply to: dirty ignition points posted by sde on September 16, 2006 at 13:03:38:
What everyone else said but I'll include this. Clean the contacts with a clean solvent such as electrical contact cleaner. I think(??) brake parts cleaner would also work just be sure ir containd no oil. Use a strip of good grade bond paper, cut not ripped to avoid any lint. Dampen the paper and drag it between the contacts. You may need to take off a little tension to avoid pulling the paper in two. Drag thru a least twice or until the paper remains clean.
Remember the purpose of 'cleaning' is to remove the nonconductive dirt not to remove the conductive face of the contact. Ever since I was taught to properly clean relay contacts I figured 'point files' were sold by the same guy who sold the points.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
