Farmall Tractors Discussion Board
Re: Re: Re: belly pump H
Posted by The Red on January 27, 2000 at 01:45:57 from (12.75.196.46):
In Reply to: Re: Re: belly pump H posted by Curious on price range for pump on January 26, 2000 at 20:01:50:
You see them in classifieds every so often. Around $150 for a functional pump and reservoir assembly. Make sure the seller is also throwing in the activation rod assembly, the 3 pipes and filler cap, and the coupling assembly.
Weight wise, at least 100 pounds!
Post A Followup
: Re: Re: Re: Re: belly pump H
