Re: Farmall H popping noise
Posted by Janicholson on September 17, 2006 at 18:33:29 from (66.173.50.59):
In Reply to: Farmall H popping noise posted by John in Ct on September 17, 2006 at 17:42:21:
If what you describe is normal backfiring, ignore it. Fuel fails to ignite when under high vacuum and the Hydrocarbons enter the muffler and ignite from glowing deposits. This can be quite spactacular at night, and sometimes is a near continuous burn like a racer. If it is a knocking noise, or metalic I would worry some. Try it at night, and if it does it then you should see the flame at the same time as the popping noise. JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
