Re: Another stuck one!!
Posted by Janicholson on September 17, 2006 at 18:50:04 from (66.173.50.59):
In Reply to: Re: Another stuck one!! posted by JayWalt on September 17, 2006 at 17:54:06:
Warm it up with the carbon torch again just to pretty hot, not violent. Then soak it in PB Blaster, or auto trans fluid for one day. Then as stated below, use a drift on the inside of the arm, both top and sides (various locations, kile putting on a wet sock, it needs encouragement from different locations to get there, moving it outward, not the shaft in. It will come off that way I'm sure. JimN
