Re: carb totally flooded on 400 ??
Posted by old on September 17, 2006 at 20:47:46 from (4.244.90.70):
In Reply to: carb totally flooded on 400 ?? posted by J Muehring on September 17, 2006 at 18:42:03:
Float sticking, or a little bit of rust or other crude has gotten in to the needle/seat area. Turn off the gas. Start the engine and let it die, then pull the drain plug out of the bottom of the carb and catch the gas in something. Turn on the gas and let it flow a few minutes, doing that may clean out any junk that has gotten stuck in the needle/seat. Or if its a sticking float do as the other guy says to do
