Re: front rim for Farmall C
Posted by gene bender on September 18, 2006 at 04:20:02 from (67.55.226.214):
In Reply to: front rim for Farmall C posted by Larry Senter on September 17, 2006 at 19:14:50:
You didnt say which rim you need as there are two types one is smooth and clamps on to the cast and the other has three brackets riveted to the rim and fasten to the hub with a bolt.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
