Re: Farmall B or Farmall H
Posted by CNKS on September 18, 2006 at 06:01:49 from (204.249.178.135):
In Reply to: Farmall B or Farmall H posted by Ryan Olson on September 17, 2006 at 21:28:00:
Having mowed with a Super A and 5ft belly mount, I will say it will be underpowered. If you keep it mowed and mow it small it's ok. Tall thick grass and weeds, no. The problem is in heavy grass or weeds you have to use 1st gear, first gear is too fast and the tractor can't handle it. I do most of my mowing in 2nd, could even use 3rd if the ground wasn't too rough. I no longer have the fast growing weeds, etc which will slow you down. If you are going to let the stuff grow a month between mowings, you will likely have probems.
