Re: SMTA Factory FH Retrofit Kit
Posted by Wardner on September 18, 2006 at 09:46:50 from (4.154.245.94):
In Reply to: Re: SMTA Factory FH Retrofit Kit posted by BOBM25 on September 18, 2006 at 08:55:23:
I fabricated a box that covers the frame cover and back of tractor. It would look something like 6" heavy angle iron over that area. Gussets went forward to tie into sides of rear frame. I will see if I can send some pictures.
The other one used a 400 frame cover. The only modification to the lid was drilling one hole for the steering column.
Hydraulic are a three spool valve bank mounted on the battery box on one and on a piece of 1/4" plate for the other. The plate has an end bent so that it fastens to frame cover bolts. Both valve banks are positioned vertically and the lever are horizontal.
