Re: Exhaust Manifold - Somewhat OT
Posted by Andy Martin on September 20, 2006 at 09:23:46 from (63.123.95.201):
In Reply to: Re: Exhaust Manifold - Somewhat OT posted by Michael Sheik on September 20, 2006 at 05:49:18:
Hitting the nut is fine, but I'd be careful hitting the bolt as you may peen the end over and prevent the nut from coming off.
Breaking off flush is not a problem because it is just as easy to weld a nut to a flush stud and the weld metal will not stick to the casting. The worst you get is a little cast metal loss around the hole and usually don't even get that.
