Re: Exhaust Manifold - Somewhat OT
Posted by glennster on September 20, 2006 at 10:24:31 from (68.77.141.137):
In Reply to: Exhaust Manifold - Somewhat OT posted by Michael Sheik on September 20, 2006 at 04:55:07:
you could try a high speed grinder with a cut off wheel, thin one. slice into the bolt like you will make a flat screwdriver slot. go thru the nut to the edge of the manifold. use a punch or chisel to split the two halves of the nut off. this will leave some of the stud sticking out of the head. you can use a stud puller on it to get the rest out. soak it up good with pb blaster or similiar product.
