Re: More hydralic questions
Posted by RoninKS on September 21, 2006 at 20:40:23 from (24.225.2.20):
In Reply to: Re: More hydralic questions posted by D Slater on September 21, 2006 at 20:00:45:
"That is a valve for 2 way hydraulic."
Thanks for the reply, that's what I thought.
"Looks like they have it hooked up to use a one way cylinder. If theres a plug in tee behind # 5 and hose 3 and 4 are togeather there using them as return to reservior."
Yes, there is a plug in the tee (very hard to see in the picture),.... and 3 and 4 look like they run together.
"hope I didn't get # mixed up. It looks like the original belley is removed and using the housing for reservior or hydraulic tank."
That's what I thought also!
"I can tell you the most common way the live pump and 2 way valve are done. The valve opening to left side of tractor, some valves have opening to front also but it and left are in same passage, this is the pressure tie in from pump on engine. This line should be teed before valve and a regulator and return line to reservior to protect pump."
OK, I'm a bit lost now, is there a diagram (or pictures)on the forum that I can look at? :>)
"2 Valve openings to rear of tactor is where lines for 2 way cylinder go. The pipe on bottom that valve is mounted to is return oil to reservior. A pipe should come out near bottom of reservior and go to pump on engine for suction"
Yes, there's a hose running from the belly to the pump (hose #7), and a hose running from the pump to the valve (hose #6).
Thanks agin for your reply.
RoninKS
