Re: 300 Utility pitman arm
Posted by Donavan A on September 21, 2006 at 21:26:49 from (64.12.116.65):
In Reply to: 300 Utility pitman arm posted by Donavn A on September 20, 2006 at 18:43:14:
Had a welder at work look at the part for me. He tacked it together ground out the break and the welded it he repeated on the other side then ground everything smooth. the arm looks brand new can't even tell where it broke. thanks for the help.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
