Re: Farmall M Hydraulic Valve Question
Posted by mmq on September 21, 2006 at 22:03:09 from (24.205.219.131):
In Reply to: Re: Farmall M Hydraulic Valve Question posted by chadd on September 21, 2006 at 07:58:24:
It sounds like you"ve had these things apart a time or two. I have a Farmall H that has a leaking trans countershaft oil seal. There is a coupling on the countershaft that drives the Hyd pump. As far as I can tell the coupling must thread onto the countershaft. How do I remove the coupling off the countershaft so I can replace the oil seal?
