Re: gasket dope
Posted by Andy Martin on September 22, 2006 at 06:49:09 from (64.219.39.195):
In Reply to: gasket dope posted by Paul H on September 22, 2006 at 06:19:53:
I'm with Allan.
If you get the joint good and clean, the gasket will seal. If you don't, the sealer may help.
At most, seal only the hot side so you have a chance to take it apart later and still save the gasket. I like to seal rocker arm cover gaskets to the head for that reason.
Straighten sheet metal covers (use a square to check) and get the metal around the holes dinged back straight, don't overtighten them and they will seal like magic without goop.
