Posted by DUNNDAN on April 11, 2009 at 09:56:41 from (168.9.18.2):
In Reply to: Re: Coil Question posted by John T on April 11, 2009 at 09:44:44:
I see what you are saying. The coil I have is a Niehoff. On the sticker it says "12V No external resister required" What do you mean when you say the distributor shorted out? The post on the side of the dist. has the wire from the + side of the coil attached on the putside. On the inside of the dist. the post has the following: a nut, then the condenser wire, then the points spring, then another nut that holds everything together. Should the condenser wire be isolated from the points spring? The points open and close fine. Gap is .021. They are new. The tractor ran fine last time I used it. Thanks for the help.
