Farmall Tractors Discussion Board
Re: Re: Re: Alternator Conversion Wiring Diagram
Posted by Dave on January 27, 2000 at 10:50:45 from (128.113.2.42):
In Reply to: Re: Re: Alternator Conversion Wiring Diagram posted by Theman on January 27, 2000 at 09:11:46:
Still a bit confused. If I start with a hand crank, and no battery at all, I'm still supposed to get voltage out (must mean this is a permanent magnet generator?)? Also, what do you mean by "the distributor ignition will operate off the generator?"
Post A Followup
: Re: Re: Re: Re: Alternator Conversion Wiring Diagram
