Re: 1939 M small gas tank
Posted by Paul G. in Mn on September 23, 2006 at 08:13:11 from (206.183.177.103):
In Reply to: 1939 M small gas tank posted by phd on September 22, 2006 at 14:57:59:
these are very hard to find. My port was loose on the bottem of mine and ended up opening it up and repairing it.I have one off a 41 and it looks like you could heat the bottem to get the sodder to flow and knock the bottem out then heat the treaded fitting and turn both upside down and would be real close the the 39 one. The mounting is a little different but you could probly fabricate one to work. I can help you with pictures if you need any. Paul
