Re: Farmall H locked up
Posted by El Toro on September 23, 2006 at 11:43:16 from (205.188.116.133):
In Reply to: Farmall H locked up posted by Streeter on September 23, 2006 at 10:16:29:
Pull the sparkplugs to see if any coolant is on top of the pistons causing a hydrostatic lock.
If there's no coolant present, pour some ATF into
the cylinders and let it soak. You may need to pull the head and drop the pan and use some persuasion with a big hammer to drive the pistons out. Use a piece of oak to drive on. Hal
PS: Some on here have rocked the tractor while in gear. Others have used the starter by just bumping the starter.
