Re: Should I think about buying this 656
Posted by PUTTER on September 24, 2006 at 17:02:39 from (69.179.203.139):
In Reply to: Should I think about buying this 656 posted by harvey wallbanger on September 24, 2006 at 16:39:39:
Hey Harold, It kind of depends on what you need it for. If you find it to run out good, even with the TA out, with the loader I would think that would be a good deal. Loader looks to be in pretty good shape and would be worth 1000 bucks around here easy. Sure would make a good snow mover or winter bale feeder. If on the other hand you are going to do alot of tillage or haying work with it the fuel cost would eat you up. I like it! PUTTER
