Re: Farmall M Timing
Posted by Bob M on September 25, 2006 at 11:31:22 from (151.190.254.108):
In Reply to: Farmall M Timing posted by Ryan Olson on September 25, 2006 at 11:12:10:
Ryan - Before you remove the distributor, rotate the crank so the distributor rotor button is pointing to the #1 tower on the distributor cap. The timing mark on the crank pulley should then be aligned with - or very near - the pointer on the front cover. If necessary turn the crankshaft a bit to align the pulley timing mark with the pointer. Then take a magic marker or similar and mark the postion of the rotor button on the side of the distributor. Now when you reassemble the engine, before you put on the rocker box turn the crank so BOTH valves on the #1 cylinder are closed and the pulley timing mark is again aligned with the pointer. Now set the rotor on the distributor to the mark you made and stick it back in - you should be all set! Note: The dist rotor will turn a bit as the distributor gear slides into the cam gear - make sure the rotor is aligned with the mark you made when the distributor is fully seated.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
