Farmall 966 High Low shifting not working
Posted by steve Mauldin on September 25, 2006 at 11:45:27 from (216.138.66.62):
After disking and seeding 40 acres with my Farmall 966, I was in the process of dragging the field to cover the clover seed and my drag bogged down so I went to shift from High Fourth to Low Fourth and it came out of High but would not go into Low or High setting but it would go into reverse without any problems. I used reverse to get off the field. I am thinking this is some sort of linkage problem but it was dark thirty when this happened and I was without a flash light. Has anyone else had this issue where the HLR lever moves into the Forward positions but it is like it is still in neutral?
