Gasket set for a 47 MD
Posted by Brad in WI on September 26, 2006 at 02:12:47 from (24.208.17.95):
Where can a guy find a cylinder head gasket set for a 47 MD with a 4" bore in it. The gaskets I would need is both manifold gaskets, cylinder head gasket, and valve cover gasket. I think I may still be able to get them at the CNH dealership but I don't care for the price that they have to offer.
Brad
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
